Weird Noise
Old Dec 26, 2012 | 05:02 PM
Thunderkiss65's Avatar
Weird Noise
Ok i have just purchased this vehicle.. 99 camaro v6. Car needed new struts and shocks, Replaced the struts and shocks, was told i didnt need to replace strut mounts so i didnt, Now for the noise, what im getting is a noise when going slow over dips and driveways etc. not really a squeaking sound more like rubber on metal but not positive, sounds like coming fron front end somewhere but cant pinpoint it, and the sound is louder when going into driveways from a angle where it compresses front end more, any help would be appreciated.
Old Dec 26, 2012 | 10:13 PM
Re: Weird Noise
The upper spring/shock mount rots, the rubber tears leaving the shock mounting ferrule loose, and will cause a clunking. You had to examine the upper mounts when you replaced the front shocks (no struts on a 4th Gen, they are coil-over shocks). What kind of condition were they in?
Scrub88's Avatar
Re: Weird Noise
Have you checked your front lower control arm bushings the rear most bushing likes to we're pretty fast also if you tightend the bottom front control arms while the car was in the air sometimes u get a squeaking bushing from that tie rods can give a bump while pulling into driveways
Old Dec 30, 2012 | 11:04 AM
Re: Weird Noise
Update. in another thread i seen where someone said to jack vehicle up about 3 inches or so and put pry bar under tire and pull up, if you have play its ball joints, come to find out all bal joints are shot. Going to replace all ball joints tie rod ends and bushings sway bar etc.
Old Jan 14, 2013 | 03:29 PM
Ultra_Z's Avatar
Re: Weird Noise
nevermind the vehicle, but my wife explorer sport would do that too. put your car on rhino ramps and crawl under front. grab the sway bar like grabbing to do a pull up but push away like upside down push up quick and fast and watch the sway bar mounts. i worked some wd40 into it and hadn't squeeked for 20k miles. i changed the end links too since i was under there.
Old Jan 15, 2013 | 08:11 PM
Re: Weird Noise
Thanks for the advice, My issue was A arm bushings and ball joints. Sway bar was fine. Thing was clunking something awful, Got them replaced and everything is good now. Oh yea replaced tie rod ends too as well.
Nayr
Mar 3, 2023 08:34 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
