Vents stopped blowing..
Weird problem. The other day the vents in my car stopped blowing. I can put it on full, and turn it to the top vents, and nothing comes out. I can hear the air blowing, but nothing is coming out. If I turn it on max AC, it gets cool, but the air comes out of the floor vents.
The windshield vent works, and the floor vents work, but no upper vents.
I pulled the HVAC fuse and that's fine. Any other ideas?
Thanks!!
Thanks!!
Re: Vents stopped blowing..
http://shbox.com/1/component_location_views.html
This will start you in the right direction. From what I have read around here, when this part goes, the HVAC system defaults to blowing out of the top and bottom vents. Please do a search and confirm.
Thanks!!
Thanks!!
[QUOTE=CamaroBoy96Z28]Is the check valve a dealer item or would any parts store (autozone, murrays, etc) have it?[/QUOTE
Good luck trying to have to monkeys at the parts desk know what a 3 way vacuum T is. Atleast the one's at the local Chevy dealership (***) can't seem to find any part without explicit help. I used RTV to cover the crack/hole in mine, has worked great for 2+ years.
Luckily that didnt turn out to be the problem. The line from the intake to the check valve was partially melted somehow and closed up enough so no vacuum even got to the check valve.
Aug 5, 2015 08:35 AM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
