UPDATE: to accesories awlays powered up with key out...
Old Jan 7, 2011 | 08:20 PM
saas's Avatar
I took the NEG battery cable off and put a test light to the NEG side. The BCM (on the pass side behind the glove box) began to click. I unplugged the large blue harness first. It stopped clicking but then my headlight motors started clicking. I unplugged the headlights and plugged the blue connector back it. The BCM started clicking once again. I unplugged the large blue connector again and left the two smaller ones in the BCM. The clicking stopped but the test light still had a very faint signal. I unplugged every plug in the BCM and still had a very faint signal to my test light.
What is my next step?
Old Jan 7, 2011 | 10:13 PM
Re: UPDATE: to accesories awlays powered up with key out...
As advised previsouly, you need to add a "Signature", with basic info about your car - year, model, engine, trans, major mods.
Old Jan 8, 2011 | 11:04 AM
saas's Avatar
Re: UPDATE: to accesories awlays powered up with key out...FIXED
It turns out it was the aftermarket radio. The guy I bought it from said that it had these problems before he installed the radio but failed to tell me that he took out a different aftermarket radio and installed another one incorrectly. Re-wired everything correctly and problem solved...
Heathen1
Jan 2, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
