Uneven stance
Old Apr 6, 2006 | 11:18 AM
shoelaces's Avatar
Uneven stance
Hello all,
Does anyone have the same issue with their camaro's where the stance is not even? I have a 99 Camaro SS where the passenger side is about 3/8 of an inch lower than the driver side? The difference is the same in front or back. The difference was slightly greater when I had stock springs and shocks. I've just recently put on Bilstein shocks from SLP and Eibach Pro-Kit springs all the way around. The car has never been in an accident and as I as I can see everything looks good. I even had some mechanics in a local shop look around and they didn't see any issues that would cause it to be off. I just wanted to know if it was very unsual to have this problem or if someone else has the same issues.
Thanks for any and all replies.
Old Apr 6, 2006 | 11:23 AM
GT KILLER's Avatar
Re: Uneven stance
Are you parked on an even surface when you're looking at it? Sometimes in my spot in my driveway, if I park too far to one side there's a bit of a dip in the asphalt and it'll look like the stance is uneven.
Old Apr 6, 2006 | 11:35 AM
shoelaces's Avatar
Re: Uneven stance
Good thought but I've checked the stance on the driveway, inside the garage and in different parking lots and it's still off. Thanks for the reply.
Old Apr 6, 2006 | 12:07 PM
Z28SORR's Avatar
Re: Uneven stance
This must have been asked a hundred times now. It's NORMAL, NORMAL, NORMAL!!! OK, rant off.
Chevrolets have been this way for probably at least 40 yrs. Walk around the parking lot and take a look. You can get coil overs and have it sit any way you like.
Old Apr 6, 2006 | 03:23 PM
LT1 POWR's Avatar
Re: Uneven stance
Yeah my 02 Suburban is like this too. I think it has something to do with torque and maybe it wears out the shocks/spings on one side of the car faster so it droops.
Old Apr 6, 2006 | 03:39 PM
MasterEvilAce's Avatar
Re: Uneven stance
Uh, what about weight? Perhaps there's more crap on the passenger side than the driver side?
Such as the battery, A/C crap, ECM..
the driver side has cruise control crap, ABS, etc.. Batteries are pretty heavy, heh.
the passenger **** is more on the outer edge of the car.. where the driver stuff is more towards the engine
Old Apr 6, 2006 | 04:53 PM
Re: Uneven stance
This question gets posted frequently on the "Suspension, Chassis and Brakes" forum. Might be worth a "search".
Old Apr 8, 2006 | 12:10 AM
shoelaces's Avatar
Re: Uneven stance
Thanks for all the replies. And sorry to the one that has heard this question asked too many times.
Old Apr 8, 2006 | 01:03 AM
Re: Uneven stance
I did a search a bit ago.. it's designed that way, so when the driver sits in.
Not very intelligent, as all drivers weigh different weights.
Old Apr 8, 2006 | 10:09 AM
Re: Uneven stance
There was no negative intent with my comment on using the "search".... I was simply trying to HELP you understand where you might find some interesting threads regarding the problem.... I kinda figure its the moderator's job to help new members.
Old Apr 9, 2006 | 04:29 PM
shoelaces's Avatar
Re: Uneven stance
The statment wasn't mean't for you "Injuneer". I appreciate the "search" suggestion. It was meant for "Z28SORR" who did not seem to like to hear this question because he had heard it many times previously. Thanks!
mark0006
Aug 22, 2015 07:23 PM
Boss002
Jul 24, 2015 10:47 AM
TitoPR221
Jan 29, 2015 08:00 PM
Collector Car
Jan 5, 2015 10:58 AM
GatotsuZeroshiki
Sep 11, 2003 07:07 PM
