turnsignal not blinking
most likely a bad socket on the tail light harness, the wire connections are flimsy and often break, usually the ground wire. Put the left turn signal on with the tail lamp removed and the bulbs hanging free. and get a spare piece of wire a few feet long. Touch the wire from the car on a clean grounding point to each turn signal bulb's metal base one at a time. The signals will start working when you find the bad socket, then replace it or the harness.
pimpinphil
May 30, 2015 04:20 PM
