Turnsignal switch?
Old Jan 29, 2003 | 03:54 PM
Formula_one's Avatar
Turnsignal switch?
Alight, I've got a 93 Formula. A couple weeks ago my driver side turnsignal stopped working. I, like any other normal person went out and bought some new bulbs, and swapped them. But to no avail!! I left it alone, because I figured I could manually push it up and down for a day or 2..Till I had more time to figure it out. Well today the passenger side went out, and thought maybe it was a fuse, it's not. Check them all. THEN I turned on the hazzards and both signals flashed "NORMALY" and still didnt work when I used the turnsignal switch. I thought maybe cleaning it out with some rubbing alcohol might work, but I cannot see anything inside to clean, but I didn't take it out of the car to do this. I would assume that it is the signal switch, but I am looking for a second opinion. Has anyone had a problem like this, or maybe tell me how to get it out with out breaking anything? Any ideas? Thanks in advance!
Old Jan 29, 2003 | 04:22 PM
chesee48's Avatar
my problem is that the turn signal when i click it, doesnt click back into thhe orignal position...when both turning right/left....
any one know a way to fix this?
Old Jan 29, 2003 | 05:30 PM
Re: Turnsignal switch?
Did you ever think that it may simply be the flasher?
Old Jan 29, 2003 | 05:32 PM
Sounds like you need to look at/replace the turn signal switch in the steering column.
Old Jan 29, 2003 | 06:07 PM
drop top steve's Avatar
Most commen problem is broken cancel springs, buck ea at gm, or it also could be part of the cancel mechinisim is broken. If it's the switch you'll need to pull the streeing wheel and lockplate. You'll need a "lockplate depresser" to get the snap ring out. Becarful of the airbag, it could move your nose to the side of your face.
If you R&R the ts switch, when you pull the harness out, attach some wire to the end so when you pull the wire harness out it pulls the wire up the coulum, then use that wire to pull the new harness down the coulum. You'll need to remove the plastic connecter first, it well not fit thru the coulum.
Old Jan 29, 2003 | 08:00 PM
Poorboy94Z's Avatar
I just had a simmilar problem last week. I replaced the flasher and it worked great. It was like $3 at Auto Zone, and took like 5 min to replace. Take off the kick pannel under you dash, and it is on the right had side behind a piece of plastic. The reason why your hazzards worked was because they operate on a different flasher. Good Luck
Old Jan 30, 2003 | 08:04 PM
Changed the flasher...Works great now.. Didnt take long...thanks for the helps guys!!
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
