Thread sealant on WP Bolts?
Old Mar 19, 2005 | 12:25 PM
defbear's Avatar
Hey guys I was wondering if you have to put thread sealant on the bolts for the water pump. I just got pretty much everything back together from replacing my water pump. I haven't filled it with coolant yet so I'm wondering if I need to can I pull each bolt 1 by 1 to put thread sealant on them? Or would that ruin the seal on the gaskets? Thanks guys.
Old Mar 19, 2005 | 05:01 PM
defbear's Avatar
Re: Thread sealant on WP Bolts?
i went ahead and put sealant on them so hopefully they seal. My only worry now is that I bought a reman water pump (autozone)and a few people I've talked to at a local Napa said that was a big mistake. They also told me that you should always replace the opti when you replace the water pump. Who knows. From searching on here I've seen mixed answers. Now I'm going to replace the plugs and wires. Hopefully I'll be done by Monday morning!!!
Old Mar 19, 2005 | 05:02 PM
Valkyn71's Avatar
I put form-a-gasket on mine, worked great.
Old Mar 19, 2005 | 06:29 PM
GreenDemon's Avatar
RULE #1 in the automotive world: Do not listen to the idiots at the auto parts stores. Of course you should buy their parts, and while you're at it buy more stuff too.
Old Mar 19, 2005 | 11:31 PM
defbear's Avatar
You are probably correct. Also I just finished up with my driver side plugs/wires. The only hard part was getting the #7 stock wire out of its stock clamps. I guess the passenger side is going to be much harder but alot of the posts I read on hear had me sweating about both sides. Then again everyone used to bitch about how hard it was to do certain jobs on my Eagle Talon and it always turned out to be a snap working on that thing.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
moparman
Feb 11, 2015 08:29 AM
cyteone
Feb 7, 2015 06:04 PM
