is their an easy way to remove the door window
Re: is their an easy way to remove the door window
there are rivets holding the glass to the window track. You'll need to drill out the rivets. It's a PITA. Use bolts with nylon lock nuts to reinstall so you never have to deal with the rivets again.
the assembled window tracks:
The top track pictured is the one that rivets to the glass. You can see where I drilled out the rivets.
Here is the hardware I used to attach the window to the track: (the rivets were unused as I substituted bolts)
and here it is assembled (it must be assembled inthe door, I assembled it outside the door for the photo only)
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
