Temp gauge stuck @ or below 160
Even after the car idles for 20 min the temp gauges NEVER goes above 160. If I remember even when I had 160 thermo in the past it still read a little higher from time to time. Plus the heater does blow heat. Could the gauge be broken completely? It does move....just not much. Thanks.
Re: Temp gauge stuck @ or below 160
Compare the reading on the gauge to the reading on a scanner. That will compare the gauge sensor in the head to the PCM sensor in the water pump housing.
If you have a 160deg t'stat, is should not even start to open until the coolant reaches 160deg, and be fully open when the coolant reaches 180deg.
I had the same exact problem, and the cause was that the previous owner had the cluster out/apart and when he reassembled it, the needle was pinched under the plastic stop. I just pulled the cluster out and reassembled the correct way being careful to not pinch any of the needles and all was well. hope this helps.
