Stripped Drain Plug
Old Apr 22, 2004 | 02:13 PM
97RedT/AWS-6's Avatar
Stripped Drain Plug
What would be the best way to fix a stripped oil pan drain plug?
Old Apr 22, 2004 | 02:15 PM
cASe SenSiTive's Avatar
Exposed Member
Is the plug stripped or the pan? If it's the plug, they sell replacements at auto parts stores. If the pan, you could buy a tap or thread-chaser and try to cleean up the threads so it will work again.
Old Apr 22, 2004 | 02:21 PM
Don't know for sure. Hopefully it's the plug. I wasn't sure if re-tapping to the same size would work, but if it is the pan, I'll try that first. What's a thread chaser?
Old Apr 22, 2004 | 02:25 PM
Exposed Member
A thread-chaser is like a tap, but doesn't cut as hard. More like an aggressively threaded bolt. Used to clean up damaged threads, as opposed to creating threads out of nothing.
Old Apr 22, 2004 | 02:35 PM
Great! Thanks for the help.
Magenta_Hearts
Mar 29, 2017 08:54 PM
gillta95
May 8, 2015 07:46 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
