Still no radio am or fm
Old Sep 9, 2015 | 04:58 PM
Bxlt1's Avatar
I posted before about this double checked everything even had a friend suggest a new radio.the connections and antenna are fine,it plays cd. .am fm radio is all static none of the speakers are blown it's the stock Bose and it always worked fine.im not into stereo systems or aftermarket radios.should I just take a chance and buy a stock one from hawks or somewhere else? Thanks again
Old Sep 9, 2015 | 10:14 PM
GaryDoug's Avatar
Prominent Member
Re: Still no radio am or fm
How do you know the antenna is fine? Try unplugging it at the radio and sticking a very small screwdriver gently into the center of the socket. Attach a 3 foot piece of wire to the screwdriver and see if it works.
Old Sep 9, 2015 | 11:41 PM
Fatdog2's Avatar
I had the same problem.I opened the hatch with the radio on and in the spare tire area I have too much antenna wire but i wiggled it around and found a place where the reception was good and duct taped it to the inside of the fender wall temp.The wire was also wound in a coil and I unhooked the coiled wire and moved the wire till I got reception.Also look for corrosion in and about the wire to antenna area. I live in a hilly area of Los Angeles so reception works or fades.Hope this helps.(After market radio with too much antenna wire for the car here.My02.
Old Sep 10, 2015 | 08:16 AM
Bxlt1's Avatar
Thanks for the replies I will do what ya both suggested. Also is there a ground under the carpet for the radio?
OutlawPerforman
Oct 30, 2017 05:40 PM
nosliw
Mar 9, 2016 04:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
