speed sensor?
speed sensor?
When I am cruising around and click my Scanmaster over to MPH, it reads like 24mph when I am going like 60mph. Whats weird is my speedo is accurate.
I would imagine the Scanmaster pulls its info form the PCM, which pulls the speed info from the sensor on the trans.
thoughts?
thoughts?
I can't figure it out. It would almost indicate that the VSS was putting out a 17 pulse/rev signal used in an M6, but the PCM was programmed for the 40 pulse/rev signal produced by the A4, and someone had inserted a signal converter like the Dakota Digital unit between the PCM and the speedo.
Wrong forum.
Wrong forum.
I think my PCM may have an auto tune in it. I know that it throws a couple DTCs that are related to an auto trans.
There certainly is no converter of any kind in there. I also have 2 different instrument clusters and the result is the same with both.
It'll be Monday before I can ask the Scanamster people.
jj_burchiel
Mar 21, 2015 12:51 AM
Jul 4, 2005 05:00 PM
