spark plug change
Old Aug 17, 2006 | 08:23 PM
lastZ's Avatar
spark plug change
when should i think about changing my plugs? i bought my car new with 15 miles on it ......it now has 33,000 miles....any suggestions, ideas? thanks
Old Aug 17, 2006 | 11:30 PM
96ZCamaro's Avatar
Re: spark plug change
spark plugs should be fine still. but if you really want to do them its not impossible like some people try to make it out to be. I used ngk iridiums or somthing like that in my car but i'm not sure on an ls1.
Old Aug 18, 2006 | 06:09 AM
teke184's Avatar
changed mine on my 96lt1 and 99ls1, both with just over 50K....and 4 of the 8 plugs on each were missing the platnum puck...makiing the gap nearly .080"...
i would change them
ngk tr55 is all you need....$2 each
Old Aug 18, 2006 | 10:00 PM
95zsean's Avatar
TAKE YOUR TIME!! I changed mine all from under the car, except#2 from above.I even cut 1 inch off a socket to get in the tight places.Make sure to put a little never seize on the threads of the plug before you put them back in, to stop them from getting stuck in the head. Good Luck.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
