recalls?
Old Aug 18, 2006 | 07:52 PM
RKPsk8er's Avatar
recalls?
Hello. I am considering a 94 z28 ls1 6-speed. were there any major factory recalls for any particular parts on this year/car?
Old Aug 18, 2006 | 08:25 PM
TraceZ's Avatar
Re: recalls?
There was no LS1 in 94.
The 5.7 V8 was called a LT1 in 1993-1997.
In 1998-2002 the LS1 was used.
Old Aug 18, 2006 | 08:43 PM
obaja's Avatar
Re: recalls?
ok, then on that note was there any recalls for the 94 lt1? just wonderin cus i got one
Old Aug 18, 2006 | 08:44 PM
RKPsk8er's Avatar
Re: recalls?
im sorry. that was a typo. I had just read a review on the ls1 before I posted that. but yeah, were there any factory recalls on 94 lt1's?
Old Aug 18, 2006 | 09:48 PM
95zsean's Avatar
Re: recalls?
I dont know about the 94 but the 95 had a problem with the 2nd gear shift forks in the trans. it would bend and cause trouble getting it into 2nd on the down shift. GM replaced a lot of them, and I think in 96 they changed to steel forks. Good Luck
Old Aug 18, 2006 | 10:00 PM
TraceZ's Avatar
Re: recalls?
There was an AIR recall. I'm not aware of any others.
AIR = smog pump. It's an electric air pump that puts fresh air into the exhaust and allows the cat to fire up sooner. GM had a problem with the electric valve inside the pump failing. The solution was a new pump with an external vacuum operated valve.
Old Aug 18, 2006 | 10:07 PM
Re: recalls?
AIR recall was applicable to 1995 and newer, not to 1994.
cmsmith
Aug 27, 2015 06:37 PM
cmsmith
Jul 10, 2015 07:19 PM
quick
Feb 10, 2003 12:40 PM
formula79
13
Nov 5, 2002 08:18 PM
WipeOutXXL
Jun 26, 2002 08:37 PM
