SLP Fan switch Question!
Old Mar 22, 2008 | 04:24 PM
19z28camaro02's Avatar
Does the SLP fan switch turn on the "High speed" fans or just the "Low SPeed"???
Old Mar 22, 2008 | 04:37 PM
Counted Out's Avatar
With my Switch (I don't think it's SLP) you can flip the switch one way and one of the fans turns on, and flip it the other way and both fans come on.
Old Mar 22, 2008 | 04:38 PM
where did you get your switch? Does it have LEDs?
Old Mar 22, 2008 | 04:42 PM
2001NBMZ28's Avatar
Both, in mine center position operatates fan temps as programmed in the PCM, then either high or low speed left or right. Also works with the ignition off so don't leave them on. Yours should be the same on a '96.
Old Mar 22, 2008 | 05:22 PM
I bought my car with it already installed, but it does had LED's, here's the picture:
Flip the switch to the right and both fans and LED lights come on, flip it to the left and one fan and one LED will come on. They will only turn on if you have power to the car, so you can leave them on and it will not be a problem.
Old Mar 23, 2008 | 04:59 AM
well that doesn't help me to get one, now does it?
Old Mar 23, 2008 | 11:24 AM
TeamingTealZ28's Avatar
The slp one. Is already pre-wired and plug and play.
It has 3 positions.
UP - Low Speed Fan Operation
CENTER - OFF
DOWN - High Speed Fan Operation
Old Mar 23, 2008 | 12:24 PM
2001NBMZ28's Avatar
I picked up a couple LEDs at radio shack and wired them to my SLP switch. One light comes on for low, both lights for high - even lights up in the center position when the PCM turns them on.
Old Mar 23, 2008 | 06:03 PM
thank you, someone finally answered my question. I'm pretty sure I get it from there. Thanks much.
Old Mar 24, 2008 | 11:27 AM
2001NBMZ28's Avatar
Here are the radio shack part numbers I used:
276-270 (red)
276-271 (green)
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
