Skip Shift Light
Old Jan 1, 2010 | 07:09 PM
94Z28LS1toLT1's Avatar
Skip Shift Light
just have a ? wat does it mean when the skip shift light pops up? When i begin driving when im in 1st gear and acccelerating the SKIP SHIFT light pops up when i get to 2500 rpm the light comes off and it will let me shift perfectly.but if i change gears before 2500 rpm when the SKIP SHIFT light comes on, it won't let me shift,but i was wondering if thats bad cuz when i shift in every gear it shifts perfect. thank u
Old Jan 1, 2010 | 07:53 PM
Skip-shift forces you to shift from 1->4 at low throttle/low rpm. That feature was added to the T56 tranny in 1994 to increase the fuel mileage rating. The Skip-Shift light on the dash comes on when the skip-shift solenoid is activated, blocking the shift to 2nd gear.
The skip-shift feature can be deleted on OBD-I cars simply by unplugging the harness connector from the solenoid on the side of the tranny. It will still set a trouble code, but no SES in OBD-I. If you add a 2Kohm resistor across the pins in the harness connector, it will eliminate the code.
Or, you can have the feature programmed out of the PCM.
Old Jan 6, 2010 | 07:48 PM
Cool hey thank u
thank u for telling me that i had no idea now i learned something new
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
Brady
Jul 29, 2002 10:30 PM
