Should I just get a new door?
Old Feb 6, 2005 | 03:47 PM
BoobSter-lt1-z's Avatar
I need your guys opinion on this,
My drivers side door has several failures to it
- THe window will not go up evenly. If I dont hold it while It is going up it
will fall towards me. It seems like a metal piece inside the door that holds
the door is broken. Someone tried to break into my car and my guess this
is how it happened
- THe door lock will not work with keyless entry or with the key. THe only way
to lock and unlock door is to move the **** left or right. I checked inside
and its a black plastic piece that is broken in a box that pushes the metal
rod that moves the lock opened or closed
- When I open the door it makes a popping sound. Looking at the drivers
door from the outside the bottom left corner of the door gets stuck with the
plastic molding and bends it back and once its pulled far enough when opening the door is slides back because it is cracked. This happened 2 yrs ago when My car was in neutral on my driveway and my friend and I were
not able to push the car forward (it had died) so it rolled back and the door
bent towards the engine compartment and was perpendicular at a 90* angle
so i believe i bent the hinges...
sorry for the long thread but what do you guys suggest ?
replace or repair? Cost Vs. repair and replacement ?
THANKS A LOT!!!!
Old Feb 6, 2005 | 05:02 PM
Need4Camaro's Avatar
Re: Should I just get a new door?
Or cost vs ease... I'd just get a new door, but 90% chance says that you'll have to get it painted to match your car...
Old Feb 6, 2005 | 05:57 PM
What if I get a door that matches the color of my car....Shouldnt be that hard to remove and install right???
Old Feb 6, 2005 | 06:22 PM
6speedZ28's Avatar
I think your biggest problem will be getting the door aligned.
Old Feb 7, 2005 | 08:15 AM
Damn!
So its not necessarily just removing the old door and putting the new one in and bolting it in where the old doors went then right? A misalignment can cause greater problems like water leaks..
Ok I dont want to do this myself anymore. I rather have someone else get really frustrated and mad and loose their appetite for the whole day. Is it cheaper to go with a new door or have the body shop repair every defect on the door?
Old Feb 7, 2005 | 02:34 PM
TraceZ's Avatar
I recently replaced my drivers door myself.
Alligning it properly requires removing the front fender. That is the only way to get to the bolts. Once you have the door latching open and closed properly, you can install and adjust the window glass.
Also, even if you get a new one, it is likely that bending the door backwards damaged the cars understructure that the hinges bolt to. It may be necessary to have a body shop straiten it.
And to top it all off, even if you get the right color door, it is likely to not match. Depending on the color of your car, GM had several different mix batches of each color. You will likely need to get the new door painted anyways.
Doors can be found shipped for under $150.00. The expensive part is getting it painted. I paid $400 to get mine done, then I installed it myself. I was very picky about how mine turned out though, you may be able to do it for less money.
Old Feb 7, 2005 | 02:47 PM
Thanks for the responses....
Hmm....just seems like its more work than what I can handle with my "Great Neck" 80 piece tool set ...I think I am gonna try to find a cheap spot to do the job or if i buy another car Ill make that a project....
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
