Security Light On Solid Only When Key is Off
Old Dec 19, 2017 | 08:56 PM
MarkC's Avatar
It's been a long time since I have posted--I am grateful for all the knowlege that is available on this site. After an exhausted search, I couldn't find any similar symptoms to what I am experiencing, so I am hoping for some help...
THE PROBLEM...
On my 97 Z28, the security light above my radio is staying lit (solid) when the key is off. When I turn the key on, the light goes out. The car starts and runs great--with the light remaining out. When I shut the key off, the light comes back on. The engine doesn't appear to be throwing any codes. Everything seems to be working normally other than this annoying light.
I performed the resistor bypass on the VATS successfully years back, so I don't think that the key is the issue here.
How can I get this annoying light to go out (other than disconneting it--which I am considering)?
Thanks for any help provided.
Old Dec 20, 2017 | 09:20 AM
GaryDoug's Avatar
Prominent Member
Re: Security Light On Solid Only When Key is Off
The Security light is not above the radio, it is in the instrument cluster assembly. There is possibly an ASR switch/light or a Second gear start light above the radio. Take a look in the the owners manual. Or do you mean in the dash top near the windshield?
https://my.chevrolet.com/content/dam...aro_owners.pdf
Old Dec 20, 2017 | 09:40 AM
In 96/97's the SECURITY light is controlled by the body control module (BCM). There are diagnostic codes for things like the SECURITY light. I believe you can pull the codes without a scanner. The procedure and code definitions should be in the factory service manual. Free download of 1996 manual, which should be same as 1997:
https://www.mediafire.com/?40mfgeoe4ctti
Old Dec 21, 2017 | 01:55 PM
MarkC's Avatar
GaryDoug--you are correct about the location--I have an LED installed where ASR switch is normally located--good catch. After a closer look, I think I have an aftermarket DEI alarm system installed that I didn't know about (I found the DEI horn)--I always thought it was a factory installed alarm system because it works with the factory key FOBs.
Did 97 Camaros come with factory alarm systems, or just keyless entry? I definitely have keyless entry.
I guess now I have an aftermarket alarm system to reverse-engineer...still want that light to go out...
Thanks,
Mark
Old Dec 22, 2017 | 08:38 AM
GaryDoug's Avatar
Prominent Member
According to the owner manual it may have the optional universal theft deterrent system. The service manual identifies it as option code UA6. The links Fred and I posted will lead you to those manuals.
Old Dec 23, 2017 | 02:00 AM
MarkC's Avatar
OK--after some digging, I think I have the mystery solved.
1. I do have the UA6 code, so my car must have come with the "universal theft deterrent"
2. I tracked down wires under the dash to locate the security system brain, and it is a DEI AM-1 module--I would have guessed it would be a GM part number, but it is clearly labeled as a DEI.
3. I found a manual online for the AM-1 alarm--it is designed to piggy back onto the factory keyless entry system
4. My alarm system was apparently stuck in valet mode--the reason the light was on. I was able to fix by following the directions in the manual--cycling the remote form unlock to lock with a door open.
PROBLEM SOLVED!
Does it seem odd that a DEI-labeled alarm system was installed as a factory option?
Thanks for the help.
Old Dec 25, 2017 | 09:41 AM
Someone added the DEI.
Old Dec 25, 2017 | 09:42 PM
GaryDoug's Avatar
Prominent Member
Seems more like "impossible".
Old Dec 25, 2017 | 11:30 PM
MarkC's Avatar
I don't know...I've owned my car for almost 20 years. I bought it used with only 10,000 miles on it in 1998. It hasn't been monkey'd with much...
Hard to believe that someone (before me) would purchase a new car and rip out the stock factory alarm to put in an aftermarket one with no additional features.
...but possible, I suppose...
At any rate, I now know what I've got, problem solved, and thanks for the help!
Old Dec 26, 2017 | 08:39 AM
GM did outsource some odd parts. The factory oil cooler on my 'bought it new' 94 was made by Modine, and still has the Modine label on it. Just a thought.
Mr_Bad_Ratchet
Nov 21, 2011 12:17 PM
Z28x
Jul 30, 2004 12:54 PM
Z28x
Jul 28, 2004 07:03 PM
Z28x
Jul 28, 2004 08:10 AM
Bryan 94 Z28
Jan 29, 2003 02:55 AM
