scanning the f body for codes
Old May 25, 2007 | 08:46 AM
afr lt1's Avatar
So, I got a couple of the idiots lights on ( ABS INOP and AIRBAG).
I want to have the car scanned for codes and do not know the best place to do this. I thought I heard of guys going to AutoZone or something.
I was talking to a mechanic and he would not give me any info on how long it would take...all the guy said was $95.00 / hour. I figure to scan it would be quick.
Who knows the deal on this?
Old May 25, 2007 | 09:36 AM
theratdude64's Avatar
Autozone Cant do a 95. Its 96+ OBDII. 95 has OBDII Connector, but OBDI computer. I dont think that would pull up ABS/Airbag anyways
Old May 30, 2007 | 11:54 AM
Compstall's Avatar
Need an ABS scanner to pull up problems with the brakes. It's separate from the PCM. And yes, scanning is a QUICK way for a shop to charge you $80 or so.
Old May 31, 2007 | 12:24 PM
afr lt1's Avatar
update with car
ok, had the car to the mechanic and they were supposed to be able to scan it. well, they couldn't.
I have the AIRBAG light on as well as the ABS INOP. They came on at the same time and everything else is good with my car. So, can anyone tell me how to fix this? I would think it would be some dang relay being as they came on at the same time. Someone please help, I am going down to Busch Gardens next week and it would be nice to have an airbag and brakes.
Old May 31, 2007 | 12:43 PM
Few scanners can access the EBCM (ABS and/or Traction Control) and airbag control systems. I doubt that local auto parts stores can do much more than the OBD-II PCM scan, which does not include ABS or airbag systems. They need a high end GM scanner (OTC Tech-2) or one of the high end systems from Snap-On, etc. As much as I hate to say it, a GM dealer is the most likely to be able to do the scan.
Old Jul 30, 2007 | 02:20 PM
94ConvertibleZ's Avatar
Did you ever figure out what was wrong? This sounds like the infamous bad ground on the passenger's side shock tower. Try cleaning and tightening the ground post if you haven't done so yet.
Old Jul 30, 2007 | 03:06 PM
It's an old thread, but yeah, it sounds like a low voltage problem. That ground is a good place to start.
Old Jul 30, 2007 | 03:10 PM
n2ceptor's Avatar
That was my problem once.....
Nut was loose..
CARiD
Feb 9, 2015 09:35 AM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
phantasm99
Aug 28, 2002 11:01 PM
Z28Wilson
Aug 1, 2002 04:27 PM
