Removing Parking Brake Cable on Rear Caliper? Need help
Old Jul 13, 2020 | 07:48 PM
WhiteWS6's Avatar
Need to remove the driver side rear caliper, I may just be an idiot but I cannot figure out how to remove the parking brake cable on it. I'm unsure of how to release tension on the cable. Parking brake is disabled and still held on the lever very tightly. Couldn't find any info anywhere, could use some help to say the least.
Thanks, Grant
Old Jul 13, 2020 | 08:10 PM
WhiteWS6's Avatar
Re: Removing Parking Brake Cable on Rear Caliper? Need help
Passenger side can be pulled off easily, but for some weird reason tension is still plentiful on the driver side so I cannot pull the cable enough to slip it off the lever. Previous owner told me a shop worked on the parking brake, looks like the driver side cable is newer but I'm not sure how it would contribute to this problem.
Old Jul 18, 2020 | 11:23 AM
WhiteWS6's Avatar
Issue Fixed- Parking brake lever on the driver side caliper was malformed partially, made removal of the parking brake cable a very tedious process. Easiest way to grease the slider pins is to remove the caliper, then break free the top (easily accessible) slider pin and actually slip the two portions of the caliper apart.
Old Aug 3, 2020 | 07:29 PM
WhiteWS6's Avatar
Here's the picture you asked for
Old Aug 4, 2020 | 03:50 PM
94Z28LS1toLT1's Avatar
Hey Grant heck yea thank you that s exactly where mine is at too. Perfect I appreciate it 😊💪👌✔💯
Old Aug 4, 2020 | 04:29 PM
WhiteWS6's Avatar
Glad to hear so!
95LT1Z28
Oct 16, 2006 09:52 AM
johnnyb
Jul 13, 2005 04:06 PM
lillbush5555
Mar 15, 2004 09:55 PM
91TransAmGTA
3rd Gen / L98 Engine Tech
15
Sep 18, 2003 01:24 PM
