radio trouble.. please help
Old Jul 23, 2004 | 09:42 PM
Kearn's Avatar
hello, my car has been sitting in the garage for a few months now and i finally have time to work on it. first thing is the radio. i uninstalled the radio a while back and touched two wires together and saw fireworks. from that time on i have had no power to my radio, no interior lights, no remote keyless entry, and no headlamp chimes. i have changed literally every fuse in the fuse box inside the car. now i dont know if there is a relay in the engine compartment that needs to be changed or not, i was hoping someone could tell me this. also, i talked to a "car guy" and he says it is most likely a fusible link that is shorted. i have no clue what a fusible link is or looks like. i was hoping maybe someone in this message board could help me out with this problem. any help would be appreciated. thanks a lot.
kearn
Old Jul 23, 2004 | 09:52 PM
rncotton's Avatar
Re: radio trouble.. please help
You said you changed every fuse in the fusebox in the car. Did you check all the fuses under the hood?
Old Jul 24, 2004 | 05:48 PM
Kearn's Avatar
thanks for the reply. no i dont recall checking the fuses under the hood, i will check those as soon as i can. meanwhile, are there more ideas of what could be wrong?
Old Aug 7, 2004 | 01:25 PM
Kearn's Avatar
hello again. sorry for the late response. i have checked all the fuses and they seem okay. my radio gets power now, i fixed a loose connection but have yet to actually check it on my radio. i will do that soon. however, my courtesy lights and my keyless entry still do not work. i thought maybe i accidentally reset the remotes somehow and just needed to reprogram them so i tried that, but i got no response from the locks. does anyone have any ideas for me to try? my next step will be to trace wires. this may be a tedious process and if someone has a simpler solution for me that'd be great. thanks a lot
kearn
nosliw
Mar 9, 2016 04:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Bxlt1
Sep 10, 2015 08:16 AM
