Q's about installing a new fuel pump
I have been doing some searching, and have found that the easiest way is going to be to cut the access hole. First off, what are the right tools. I am guessing probably just a dremel and some hand tools. The new pump is a Holley 255, almost identical to the Walbro, but do I need any sort of adapters for this pump to work? Is there anything I am missing? Do I need any sort of new gaskets or other parts? any other good writeups? I checked shoebox's site, I didn't see one on there. TIA!
Re: Q's about installing a new fuel pump
I'm thinking a dremel would take a while. Do you have access to an air powered die grinder? That and a cut-off wheel would make pretty quick work of it. Don't forget the eye protection as well, when you get a small piece of metal in your eye from using a die grinder it tends to cause irritation, making it look like you've been crying, and people tend to look at you like "what the hell is wrong with that guy?!"
<don't ask me how I know>
I didn't use a Dremel.. I took the wimpy way out and drilled a large hole in two corners and used tin snips to cut it.. HERE'S my thread with links how to do it.
I did a full write up seen HERE.
I used a dremel, which didn't take very long at all. Maybe 10 minutes tops, and that was mostly to change cutoff wheels.
What about some sort of harness, like a painless wiring harness. I noticed that there is a kit that from thunder racing that has the pump and the wiring harness. If I have a holley pump, can I just order this harness, or how much work has to be done to adapt the wires to the ones in the tank?
i just did this, and i have some tips. i did the dremel method. took forever cause i kept grinding wheels away and/or breaking them. after that spray the quick releases down with carb cleaner or something. undo everything. i tossed the bucket but i coulda used it if i wanted. i chose to just use two hose clamps of medium size and put it on that way. make sure you get 50PSI or higher fuel/emission hose and make sure your tighten your clamps down very tight. i had 4 hoses come off and/or break on me. now i have no problem other then blowing the **** out of my tranny
Originally Posted by Blown_Red_97z
thanks for all of the info, but anyone have advice about the whole wiring thing? Its not just plug and play right, I need to get that adapter?
The racetronix pump I got (pump only, no harness) came with glue for the cup housing and lube for the o-rings. I'm not exactly sure what it was though....
