Power Windows
Old Jul 26, 2020 | 09:55 PM
patpkk's Avatar
Power Windows
Does anyone have a wiring diagram for a 1997 Camaro fuse block inside the car.
I am specifically looking for the power feed for the power widow breaker.
I am thinking It has to be a switched ignition feed. I have no feed to the breaker in the fuse panel, does anyone know where it comes from?
Thanks.
Old Jul 26, 2020 | 10:27 PM
Re: Power Windows
Free download of 1996 factory service manual, 99% identical to 1997. Courtesy of GaryDoug:
https://www.mediafire.com/?40mfgeoe4ctti
Old Jul 26, 2020 | 10:30 PM
Re: Power Windows
And Shoebox has 1996 power distribution.
http://shbox.com/1/ignswschematic96.jpg
Also body control module. That contains retained accessory power (RAP) supply for windows. Deterioration of the PC board often cause loss of power.
http://shbox.com/1/bcm_1996.jpg
Old Jul 27, 2020 | 08:36 AM
ray42's Avatar
Re: Power Windows
Patpkk,
Injuneer is there, I betcha. I had a problem with my power windows; they would work, or not, as they might see fit. Thought it was a circuit breaker, or maybe bad wiring.
The BCM had busted solder joints at the board connector (common problem). Got the BCM connections re-soldered for cheap, now good as new.
BushyTea
Jun 6, 2009 04:47 PM
67ProStreet502
Oct 5, 2006 07:02 PM
tamatt27
Aug 22, 2004 04:56 PM
96 WS6
Nov 11, 2003 01:14 PM
95BLKTA
Mar 23, 2003 09:24 PM
