Power Side Mirrors Not Working (1993)
Old Mar 4, 2015 | 06:32 PM
guruerror's Avatar
Neither of my side power mirrors will move. I've replaced the control...same result. The car was in storage for about 7 years...just put it back on the road. I'm not sure if the problem existed before storage or not.
Do these mirror motors typically fail/lock-up? I'm debating on whether to pull the trigger on a set of aftermarket mirrors but I thought I'd throw this out there for feedback first.
Thanks in advance.
Old Mar 4, 2015 | 07:31 PM
Re: Power Side Mirrors Not Working (1993)
Not a common problem.
Old Mar 4, 2015 | 08:36 PM
GaryDoug's Avatar
Prominent Member
If your car has power door locks and power hatch release and they don't work also, check the PWR ACCY fuse.
Do both directions not work on both mirrors?
Old Mar 5, 2015 | 08:52 AM
guruerror's Avatar
Yeah...door locks and hatch release work. The fuse is good.
Neither mirror will move at all...in any direction. When moving the mirror control stick around attempting to adjust the position you can occasionally hear an audible pop sound come through the speaker system.
Old Mar 5, 2015 | 08:52 PM
GaryDoug's Avatar
Prominent Member
Sounds like a bad connection somewhere. I would check the orange wire at the switch for 12v when the ignition switch is set to Run/on. Then check for a constant ground at the black wire. Keep in mind that both wires go through the door jamb cable set and may be intermittent. Those wires are the only ones common to all directions and mirrors.
The black ground wire goes to the left door pillar behind the kick panel: http://shbox.com/1/fuel_pump_relay.jpg
It's just behind the word "kick"
Old Mar 5, 2015 | 11:33 PM
Fatdog2's Avatar
I would pull the door panel off and re-connect the switches and turn the key on but don't start the engine and take a look at the little connector that connects the power mirror to the wiring connector thing and move it around (plug it in and out several times to see any movement)Call me crazy but I would do the cheap stuff first.Hope this helps.(Was the car exposed to bad weather conditions).Maybe the little motors in the mirror need a little help with movement.My02.
Old Mar 10, 2015 | 12:19 PM
guruerror's Avatar
Good to know...I'll check into this this weekend.
The car's been garage kept (off the road) for the last seven years or so, before that it's seen it's share of normal east coast (Maryland) weather.
I tried giving the mirrors a little 'help' when moving the control stick. They're pretty firm. With enough pressure they can be moved with an audible click like little plastic gears slipping.
I'll follow-up on this and report back. Thanks for the guidance.
Old Dec 12, 2020 | 06:12 PM
Jerry Crumpton's Avatar
My 99 SS does the same thing. I just got this car and that was the only thing that didnt work... I just hear this pop sound when i try to move the switch. I am curious if you ever figure out the issue ??
Old Dec 12, 2020 | 06:32 PM
“Guruerror” hasn’t signed into this site since 2015.
I can post the wiring diagram from an earlier year. As GaryDoug explained above, check the “power accy” fuse, and check for 12 volts on the orange wire at the power window switch assembly. Check for a good ground on the black wire at the switch. After that you need to check for 12 volts out of the switch based on which way you are pressing the switch.
From Shoebox:
http://shbox.com/1/1995_fbird_pwr_mirrors.jpg
99 may be a bit different, but you can download a free copy of the 1999 factory service manual (courtesy of GaryDoug) and compare the power mirror wiring schematics.
.https://www.mediafire.com/?40mfgeoe4ctti
SSCAMARO1659
May 8, 2009 08:57 AM
cerveza4lu
Sep 18, 2006 09:59 PM
JMiller
V6 Tech
Jun 25, 2003 08:03 AM
JMiller
Jun 20, 2003 01:06 AM
XThree
3rd Gen / L98 Engine Tech
Feb 23, 2003 09:39 AM
