Passenger window not rolling down
Old Oct 14, 2024 | 01:56 PM
JacksonZ28's Avatar
Hey everyone, I have a 97 Z28 which the passenger side window won’t roll down. I replaced the motor back in March or April of this year. I checked the 30 amp fuse that was located in the side panel and it is good. I was seeing if there was any other things I can test. The motor was a Dorman brand. Thank y’all for the replies.
Old Oct 14, 2024 | 04:09 PM
Re: Passenger window not rolling down
Did you try to operate the passenger side window from the switches on both sides of the car?
Have you checked for 12 volts on the “Down” terminal of the switches on both sides of the car when operating the switches?
Did you clean and lube the window tracks when you replaced the motor? If the factory service window binds the thermal breaker inside the motor assembly will trip.
Here's a 1995 schematic.
http://shbox.com/1/pwr_window_schematic.jpg
http://shbox.com/1/window_motor_switches.jpg
Might be different from the 1997. But you can download a free copy of the 1996 manual (99.9% same as 1997):
https://www.mediafire.com/?40mfgeoe4ctti
Old Oct 14, 2024 | 04:27 PM
And since this isn’t an “engine” problem, let's move it to “General F-Body Tech”….. more traffic there than “Car Audio and Electronics”.
Old Oct 14, 2024 | 06:26 PM
JacksonZ28's Avatar
I tried both switches neither of them would work the driver side rolls down fine. I lubed the tracks. I will have to check the voltage on the switches this weekend. Thank you for the replies.
Old Oct 17, 2024 | 04:09 PM
JacksonZ28's Avatar
Update on the passenger window. I was able to bypass the passenger side switch through the driver side by running jumper wire between terminals E and C and between terminals B and D. The window still didn’t go down with just the driver side switch while testing I noticed the lights dim and a faint click can be heard from the passenger side switch. Could this mean it’s the switch or is the motor not engaging? Thank y’all for the replies.
Old Oct 17, 2024 | 05:31 PM
Is the click from the passenger side switch, or is it possible it’s from the thermal circuit breaker inside the motor assembly tripping?
And just a heads up….. there’s hardly anyone active on this site any more. And off-hand, I don’t know where you can find more help. I owned my purchased new 1994 Formula for 28 years and never had a problem with the windows, so my knowledge is limited.
Old Oct 17, 2024 | 05:38 PM
JacksonZ28's Avatar
The sound sounds like it is coming from the switch. I did the voltage test on the dk blue wire and the switch down the voltage is 0.01 to 0.05 while pushing the switch up the voltage went up to 11.59. I also tested the brown wire that goes to the motor and it shows 12 volts when the switch is down and 1.30 when the switch is up. While I was testing the dk blue wire the motor kicked on and sounded strong so I know it’s got to be a loose connection somewhere. Thank y’all for the replies.
Old Oct 21, 2024 | 06:29 PM
JacksonZ28's Avatar
Update on passenger window. After further diagnosing I found that there was something internally wrong with the window motor. I replaced the motor and the window is working fine now. Thank y’all for the replies to this issue.
Old Oct 21, 2024 | 09:38 PM
Thanks for the follow up. Wish everybody would do that.
415Z28
May 2, 2010 09:59 PM
UT DAVE
Feb 21, 2005 12:09 PM
b-stevens
Aug 25, 2004 06:56 PM
LanceJoker
Feb 15, 2004 07:53 PM
