Opti Internals. What's This?
Old Dec 19, 2015 | 03:51 PM
snorkelface's Avatar
I did diagnostics and it seemed to point that my opti had gone out after only 500 miles. It was installed by the shop when they put in the turbo setup. I found that they removed the opti vent lines and just left it venting to atmosphere. This is what I found when I opened it up:
To me it looks like it's build up from not being vented. I bought an MSD cap and rotor kit, but is this something I can just clean all of the points and the rotor and reinstall?
Attached Thumbnails Opti Internals. What's This?-1450561796001159249219.jpg   Opti Internals. What's This?-1450561829512841534928.jpg
Old Dec 19, 2015 | 07:00 PM
Re: Opti Internals. What's This?
It looks like corrosion, typically due to ozone buildup. The vent system is there to remove the ozone. Should be able to clean it up.
With your turbo you need to find a way to vent it without exposing it to pressure, or excessive vacuum. The shop probably couldn't figure out how to deal with it.
Old Dec 19, 2015 | 08:26 PM
GaryDoug's Avatar
Prominent Member
How is the power brake booster working? Do you have a separate pump?
dark-evader
N2O Tech
Dec 21, 2015 11:16 AM
War Engine
Aug 20, 2015 06:13 AM
warmeck
Jun 5, 2015 05:19 PM
jmadoll
May 27, 2015 07:13 PM
Nellsw88
May 26, 2015 05:55 AM
