o2 sensor tool avalible?
Old Jun 28, 2005 | 05:39 PM
1 BADD AZZ Z's Avatar
i just wanted to ask if there was a o2 sensor tool avalible. if not what would be the easiest way to remove and replace the sensors?
Old Jun 28, 2005 | 06:10 PM
Re: o2 sensor tool avalible?
Just about any auto parts store should have an "O2 sensor tool"... basically nothing more than a deep well socket with a slot cut in the side of it so it can fit over the wire. Problem is, its very hard to fit the socket on the sensors in the stock LT1 locations, and then get a ratchet on it. You end up using an open end wrench. Usually helps if the exhaust system is hot when you try and break the sensor loose.
88IROC_Z
Jul 22, 2015 11:38 PM
Catmaigne
Jul 14, 2015 05:17 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
