Not blowing warm air?
Old Oct 28, 2008 | 08:27 PM
  #16
Drive XR7's Avatar
It's old. Your heat isn't going to work as well as a newer car. I'm discovering this in my Cougar now. It once overheated because the t-stat didn't open... cold air the whole time.
Old Oct 28, 2008 | 08:34 PM
  #17
95Z28LT1-PA's Avatar
So it could be my thermostat...Guess I should replace it, is it hard?
Old Oct 28, 2008 | 08:38 PM
  #18
shock6906's Avatar
Originally Posted by 95Z28LT1-PA
Did go there...no answers, Where is the thermostat located and how do I detect if it's faulty?
That's why you would have posted this in the tech section. That way, in the future, when someone else had this same question they'd be able to search and they would find it in the LT1 tech section. There's a reason the forum is segregated into different topics.
Old Oct 28, 2008 | 10:29 PM
  #19
There are several "no heat" threads going right now (a couple in LT1 Tech). Most of the time the heater core is clogged. The no heat question is asked every fall when the weather turns cold.
https://www.camaroz28.com/forums/sho...62&postcount=2
If you need it, you can find thermostat change info on my Tech Page.
http://shbox.com/1/4th_gen_tech2.html#thermostat_change
Old Oct 29, 2008 | 09:18 PM
  #20
Thanks so much man, be doing that tomorrow...along with changing my drivers side lo-beam...what a pain!
Old Oct 29, 2008 | 09:57 PM
  #21
The headlights are pretty easy. Take out a couple torx screws, swing bezel open, replace bulb, put screws back.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
kksi
Feb 17, 2015 10:41 PM
95chwagon
Jan 13, 2015 09:19 PM
Britbilly
Jan 7, 2015 08:49 PM
