Not blowing warm air?
Old Oct 28, 2008 | 04:48 PM
95Z28LT1-PA's Avatar
My car after being serviced, decided to not blow hot air...it blew warm air before *but not hot* it had a antifreeze leak but that was repaired and is now full of antifreeze but still get no warm air. I noticed last night after the car was idiling for a little bit, a film developed on my windshield...it wasn't the normal heater core film but it was there. I wiped it off and it didn't come back...it could have been cause it was snowing and stuff and that's why it was there. Same story today beings we had 5 inches of snow! But I had to go buy a portable heater *does not blow enough air at ALL!*. So what could this be? I'm thinking thermostat or heater core...again, my antifreeze is full
Old Oct 28, 2008 | 04:50 PM
JAB's Avatar
JAB
I'd check the thermostat first. Make sure it's not staying open.
Old Oct 28, 2008 | 04:53 PM
Where would that be and how could I check that? I'm trying to accomodate myself to working on this car myself
93transam1234's Avatar
i am guessing this isnt a political thread, ahahahahahahhah
Old Oct 28, 2008 | 04:58 PM
shock6906's Avatar
All those tech sections gone to waste.
Old Oct 28, 2008 | 05:04 PM
I don't think it could be my thermostat cause my temp gauge isn't going haywire and it never overheats, just doesn't blow hot air
Old Oct 28, 2008 | 05:06 PM
Zaknafein's Avatar
But it DOES "blow" air??
Old Oct 28, 2008 | 05:10 PM
Yes it blows air...Not hot air like it should
Old Oct 28, 2008 | 05:11 PM
Gord's Green Z28's Avatar
What is your temperature gauge at?
What did you get serviced? Did you try opening the radiator cap with the car warm and the inside set for heater? (circulates the coolant through the heater core and lets the air out.)....On a 4th gen, you'd be opening up the screw on the coolant line to let any air bubbles out.
If you've got a 160° thermostat in there, you'll never feel warm inside the car. LT1's need the stock 180° thermostat.
This time of year, you want the radiator fans off or at the stock settings.
Old Oct 28, 2008 | 05:20 PM
I had my opti replaced and they replaced my water pump gaskets. My temp gauge usually stays right in the middle or a touch below and sometimes a touch above, so dunno what that means. I haven't tried any of them tips yet, I want to do something before I have to go out and spend some cash, so let's try the free tips first
Old Oct 28, 2008 | 05:26 PM
mdenz3's Avatar
Free trip: Tech sections are great places to get good answers to technical questions.
Old Oct 28, 2008 | 06:09 PM
Did go there...no answers, Where is the thermostat located and how do I detect if it's faulty?
Old Oct 28, 2008 | 06:28 PM
And I know it wasn't my heater core cause there is no leak anywhere...what 2 do?!
Old Oct 28, 2008 | 06:37 PM
Erik's Avatar
Classic Tech Moderator
If the t-stat is not functioning properly it will be stuck open, allowing coolant to flow through radiator. This makes for cooler coolant, and in cold weather, a poorly functioning heater. When the t-stat is working properly, it stays closed until the coolant reaches 180º, then it opens and makes for a toasty warm heater.
I suppose you could test it, but they're cheap, just get a new one. If you really want to test it, put it in a pot of water with a thermometer and heat up the water on the stove. The t-stat should open up at 180º (unless someone installed a 160º thermostat). I don't have a Camaro, so I can't tell you exactly where the t-stat is located, but you might consider getting one of those Haynes manuals - it'll show you how to do all kinds of basic maintenance.
Most likely location - follow the upper radiator hose to where it connects to the top of the engine.
Disconnect the hose from the thing it's attached to (water neck), then remove the water neck. The t-stat will be right underneath just sitting there loosely and can be picked out with your fingers.
Old Oct 28, 2008 | 08:22 PM
Eric_96Z's Avatar
I really dont know what the other guys are talking about but I have a 160 degree thermostat and it blows warm air..
