Non-Keyless Entry converting to Keyless Entry
Old Jan 30, 2007 | 04:40 PM
khojo16's Avatar
my car has the RPO code AU3 which is just for power door locks, and power hatch release...if i have a keyless entry remote and a BCM w/ keyless entry sitting here and i install the BCM and program the remote...do i need anything else to make my car have keyless entry?
Old Jan 30, 2007 | 05:00 PM
Dave89IROC's Avatar
probably not, install the RKE BCM and program the remote, see if it works, if not, put the old BCM back in
one thing, the VATS functions are in the BCM, so, if the RKE BCM is used, you will need to find out if the VATS can be reprogrammed to match your car
Old Jan 30, 2007 | 05:04 PM
khojo16's Avatar
The RKE BCM is brand new and coming from GM...so i should be good to go right?
Old Jan 30, 2007 | 05:15 PM
PentaVolvo's Avatar
it prly needs to be programmed for your vats. Goin to an aftermarket keyless system would be much easier in the end IMO
Old Jan 30, 2007 | 05:41 PM
khojo16's Avatar
with 96-97 BCMs the vats and keyless entry are all programmed in the BCM, and it will recognize the resistance of the first key i put in the ignition to start the car...and then once i program the remote everything should be fine and VATS shouldnt have anything to do with it tho...right?
Old Jan 30, 2007 | 06:56 PM
I think that's right.
Old Feb 1, 2007 | 10:44 AM
khojo16's Avatar
just as a follow up...installing the new BCM and then programming the keyless remote worked great! thanks for the input guys
2QUIK6
Sep 17, 2016 02:31 PM
bunker
Aug 21, 2015 10:21 AM
Slayer
Aug 17, 2015 03:55 PM
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
