Non-Keyless Entry converting to Keyless Entry
my car has the RPO code AU3 which is just for power door locks, and power hatch release...if i have a keyless entry remote and a BCM w/ keyless entry sitting here and i install the BCM and program the remote...do i need anything else to make my car have keyless entry?
one thing, the VATS functions are in the BCM, so, if the RKE BCM is used, you will need to find out if the VATS can be reprogrammed to match your car
with 96-97 BCMs the vats and keyless entry are all programmed in the BCM, and it will recognize the resistance of the first key i put in the ignition to start the car...and then once i program the remote everything should be fine and VATS shouldnt have anything to do with it tho...right?
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
