no power to fuel pump solution!!!
Old Mar 29, 2005 | 11:29 PM
littlbasterd's Avatar
have had a problem the past few days.. she starts she doesn't she starts she dosn't. i turned the key to the on posision could not hear the fuel pump power up like you always can on a gm. i traced the prblem down to the main ground wire underneath the drivers seat. the conector gets coroded over time of the wonderful t-tops leaking. since gm put the main ground on the lowest point of the car all the water collects and corods the ground connector. easy fix to a small problem. from what i hear many people have replaced fuel pumps because of this problem. so i thought id share my newly learned info with all of you incase you didn't already know that. and to save you all the head ache of replacing a fuel pump
Old Apr 13, 2005 | 06:17 PM
JC's Avatar
JC
Member
Re: no power to fuel pump solution!!!
I'll have to check that out. I've got a weird fuel pump problem. It like a short somewhere in the wiring. I'll be driving and it will cut out on me, but if I shake the car, it'll come back on.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
