New TA owner, already a problem :(
Old Sep 26, 2005 | 02:28 PM
  #16
1995greenTA's Avatar
Re: New TA owner, already a problem :(
Originally Posted by 95patriotZ
I think you may have been unlucky... don't discourage him back into owning a mustang! Anyways they aren't that bad at all, yes just like any car, parts do wear out in due time. With 51k you will have a while yet. Enjoy the car, Wish i knew more about the AC system. Good luck.
Well maybe to get your hopes up....I havent had much trouble at all after all of those were replaced.
Old Sep 26, 2005 | 08:55 PM
  #17
torque6730's Avatar
Alright, got some pictures tonight. At the bottom of the housing, there's about a 1/4 inch wide channel that runs the length of the housing and tapers off as it goes towards the driver side. This channel appears to be a hollow space that was poorly sealed by a rubber compound. I still don't understand why the water is exiting here instead of the drain hole. I hope I don't have to take the housing apart and reseal it. Any ideas on how to fix this?
Here are the pics:
Wide view from the passenger seat.
http://img39.imageshack.us/img39/334...onleak15ju.jpg
Close up view of the underside. Arrow shows the leak.
http://img247.imageshack.us/img247/9...onleak32jz.jpg
Old Oct 16, 2005 | 09:13 PM
  #18
torque6730's Avatar
UPDATE
I removed the heater core today to get a closer look at the evaporator. The drip pan is intact and free from debris. It almost looks like the fan is blowing the water out of the pan and into the pass. compartment. Should there be some sort of seal or insulation underneath the evaporator to channel the air through it? The air seems to be blowing right underneath it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mattstrike
Mar 11, 2015 07:33 PM
mspennyhughes
Mar 1, 2015 03:50 PM
mritter1965
Feb 9, 2015 07:01 PM
