New TA owner, already a problem :(
Old Sep 25, 2005 | 06:14 AM
torque6730's Avatar
Hi everyone. I recently purchased a mint (I thought ) 95 Trans Am a4 with 51k. Everything was going fine until I noticed a pool of water on my passenger side floor. I tracked it down and the leak is definately coming from the ac evaporator. The drain hole on the bottom is clear and damp, so I know some of it is actually getting out of the car. I noticed the leak from the bottom of the box in the passenger compartment. Apparently, there is a seam in the box that was originally sealed with a rubber compound that has just worn out. I tried sealing it with some silicon cement but it just won't hold. Anyone else have this problem? I'd appreciate any help.
Old Sep 25, 2005 | 07:17 AM
Blue89Bird's Avatar
Re: New TA owner, already a problem :(
the drain is probably clogged. Take a wire hanger and clean it out.
Old Sep 25, 2005 | 07:35 AM
torque6730's Avatar
Yeah, that's the first thing I checked. It's all clear.
Old Sep 25, 2005 | 09:49 AM
StripedFomula's Avatar
is it water or is it coolant? does it have a sweet smell? if it is coolant, your heater core most likely got a leak in it. some cars drain it outside the car through a weep hole, others drain it right onto the passenger floor. im not sure where it goes on the fbodies though.
Old Sep 25, 2005 | 10:42 AM
Blue89Bird's Avatar
right on the passenger side floor on fbodies. I've had to replace them on every fbody I've owned, and its a royal PITA.
Old Sep 25, 2005 | 04:55 PM
torque6730's Avatar
It's definately water.
Old Sep 25, 2005 | 04:59 PM
Z95m6's Avatar
Its just condensation off of your AC, no big deal they all do it.
Old Sep 25, 2005 | 05:05 PM
1995greenTA's Avatar
Get used to having problems. I bought a "mint" 46k 95 Transam. It was in the shop at least once a month for the first few. Things start going wrong. Clutches, water pumps, optis, differentials. window motors, headlight motors, fuel pumps, etc. You might be a lucky one and not have any of these problmes for a while, but expect them.
Old Sep 25, 2005 | 05:07 PM
torque6730's Avatar
It's supposed to drain onto the carpet?
Old Sep 25, 2005 | 05:10 PM
torque6730's Avatar
Damn, that's not what I wanted to hear. The engine looks like a royal pita to work on. Maybe I should have kept my mustang.
Old Sep 25, 2005 | 05:54 PM
Z95m6's Avatar
sorry i thought you meant it was dripping on the ground.
Old Sep 25, 2005 | 06:17 PM
Blue89Bird's Avatar
If you can take a picture of where it's actually leaking from, or find a pic of it on shoebox's website, I'm sure we can figure out how to fix it.
it is. It's a real PITA, but they're great engines that don't really require all that much work very often.
Your opti will probably need replaced at some point in the near future, people make it sound worse then it really is. Few hours to replace and you're good for another 7-8 years. Your coolant sensor will probably go out soon as well, they're like $20 from Dal and take 30 mins to replace.
Old Sep 25, 2005 | 06:19 PM
95patriotZ's Avatar
I think you may have been unlucky... don't discourage him back into owning a mustang! Anyways they aren't that bad at all, yes just like any car, parts do wear out in due time. With 51k you will have a while yet. Enjoy the car, Wish i knew more about the AC system. Good luck.
Old Sep 25, 2005 | 07:38 PM
torque6730's Avatar
Thanks for the input guys, I'll grab some pics of the leak tomorrow.
Old Sep 26, 2005 | 01:56 PM
FroSSty's Avatar
If the tube is clear then there may be a crack in the plastic housing that the evaporator is in. I would pull some of the stuff out of the way to gain access to the housing, turn on the air and visually inspect for water coming out. good luck.
