Need help removing alternator casing...
Old Mar 3, 2007 | 04:38 PM
nb 96 z's Avatar
Its kinda stuck or I'm not doing it right. All 4 retaining bolts are off as well as the pulley nut. Am I missing something??
Old Mar 3, 2007 | 05:00 PM
The Engineer's Avatar
If you're planning to rebuild it, just get a parts store rebuild. The old GM units could be rebuilt at home, however, the late-models are difficult to impossible.
WD
Old Mar 3, 2007 | 05:02 PM
wrd1972's Avatar
The halves can be very tight to the ring (thing with the coils). I had to do some prying. The front bearing is pressed into the front case half but the rear is free.
Dont freak out when the brushes pop out after you separate them and dont lose the springs.Yyou will need a very small allen wrench inserted through the rear case to hold the brushs in during reassmbly. The whole thing is fairly intuitive.
mdacton's Avatar
WD
not to mention its getting harder to find the parts also....
Old Mar 3, 2007 | 05:15 PM
FlamingChicken's Avatar
i just used a rubber mallet and tapped on the little ears until it dropped. Unless you are just replacing the brushes I wouldnt bother rebuilding it. I rebuilt mine and had to change the voltage regulator bc it was overcharging and the regulator died after a bit over a year. I bought both the regulator and the brushes from oreillys. Its not hard just not worth it due to the quality of parts available imho
Old Mar 3, 2007 | 05:17 PM
LiENUS's Avatar
you guys all assume hes rebuilding, perhaps hes just polishing it?
Old Mar 3, 2007 | 05:29 PM
OBE1 95Z28's Avatar
Here's some good info: http://www.zmydust.com/alternator.htm
Old Mar 3, 2007 | 05:55 PM
nb 96 z's Avatar
Yup. That's what I'm doing. Thanks for the link OBE. I looked at it last time I posted, and it is very helpful. I shouldn't have a problem putting it back together, just gotta get it apart first! I'll try beatin' it with a malet. Thanks guys.
Old Mar 3, 2007 | 07:11 PM
slowZ's Avatar
i was on autozone's(or maybee advanceauto) web site the other day and you can get anything to rebuild them, and i think they are pretty much common sence to rebuild if you you can diagnose whats bad in them.
Old Mar 3, 2007 | 08:48 PM
LiENUS's Avatar
You can replace the regulator, the bearing or the brushes, beyond that I don't think you can go further into a rebuild. While thats almost everything its not quite everything you could replace.
DirtyDaveW
Dec 1, 2016 05:37 PM
DSMKilla
Jun 11, 2015 05:02 PM
eanhl2004
Apr 4, 2015 12:01 PM
Gtpguy
Jan 26, 2015 04:50 PM
