Need help installing Gauge
Old Aug 23, 2005 | 03:28 PM
$750 LT1's Avatar
I have a 1995 LT1 camaro, and need help installing an A/F ratio gauge.
There are 3 wires coming out of the gauge. One is a ground (black). the other Power (red). I can do those. But there is a violet wire that goes to the o2 sensor signal. Now where do I get the signal from? Somewhere on the PCM? Any help would be greatly appreciated.
Thanks,
Daniel
Old Aug 23, 2005 | 03:48 PM
Re: Need help installing Gauge
Either the left O2 sensor (purple/white wire from pin C20 on the PCM) or the right O2 sensor (purple wire from pin C8). Splice into the wire somewhere between the PCM and the harness plug. Do NOT splice into the actual O2 sensor wires.
If you want to be able to select either sensor, wire the two sensors to the outer terminals of a single-pole/double-throw switch, and put the purple wire from the gauge on the center terminal.
Moving to "General F-Body Tech...."
Old Aug 23, 2005 | 08:18 PM
crazypurgatory's Avatar
Lightbulb Re: Need help installing Gauge
Thanks,
Daniel
Or you can go to casperselectronics and get 2 of these.
https://www.casperselectronics.com/M...camaro1996upv8
I can't beleave how maney people just want to cut there wireing harness.
Chris G.
Old Aug 23, 2005 | 08:32 PM
$750 LT1's Avatar
Thanks for the help!!! I appreciate it!!
Sorry for putting it in the wrong section.
Thanks for moving it.
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Collector Car
Jan 5, 2015 10:58 AM
ro2207
Dec 4, 2014 06:18 PM
