will my fuel gauge work without PCM?
Old 05-28-2007, 04:39 PM
mdacton's Avatar
just wondering....don't have a PCM anymore
mdacton is offline
Old 05-28-2007, 06:54 PM
The PCM has nothing to do with the fuel gauge AFAIK.
shoebox is offline
Old 05-28-2007, 06:58 PM
mdacton's Avatar
o.k.
What else will work? nothing?
water, amp, oil? If not then I need to order some gauges asap
mdacton is offline
Old 05-28-2007, 09:10 PM
Only the tach and the speedo are driven by the stock PCM. Both can be connected without the PCM. Coolant, system volts and oil pressure are direct wired from sensors, not the PCM.
Injuneer is offline
Old 05-28-2007, 09:17 PM
mdacton's Avatar
so fred I have an old harness.......I can just find the wires and plugs I need and hook up the other gauges? If so that would be good for now, I don't need the tach or speedo
Thanks for the help guys
mdacton is offline
Old 10-30-2007, 06:52 PM
mdacton's Avatar
shoebox hope you can help me again....
What did I need to do in order to make the stock alt. work? I know you said wire a resistor to a switched 12v but how much was it?
If anyone can help thanks
mdacton is offline
Old 03-10-2018, 02:28 PM
Villin's Avatar
Re: will my fuel gauge work without PCM?
new sending unit Gage won't work no pcm can play
Villin is offline
Old 03-10-2018, 02:38 PM
Could you provide basic info, like the year of the car? Could affect the answer. And not sure what "no pcm can play" means.
In the meantime, if it's a 93-97, read this:
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
Injuneer is offline
Old 03-10-2018, 08:57 PM
Villin's Avatar
I have a 98 Camaro with stand alone pcm and harness no factory pcm will my gas Gage work
Villin is offline
Old 03-11-2018, 12:41 PM
NO
This is why we need to know the basic info. Up through 1997 the level sensor is wired directly to the fuel level gauge. In 1998 they changed the setup, and the level sensor signal requires the PCM to interface with the fuel level gauge. Generally, it makes sense to keep the stock PCM (in addition to the aftermarket ECU) for functions like the speedometer, tachometer, and starting in 1998 the fuel level gauge.
Injuneer is offline
Garcia5
07-07-2022 06:51 PM
sdn1997rs
12-30-2014 08:30 AM
ANDYZ28
12-29-2014 09:13 PM
blac94Z
11-24-2014 07:12 PM
07-04-2005 05:00 PM
Quick Reply: will my fuel gauge work without PCM?
