Minimum driving distance for proper oil operation
Old May 24, 2008 | 08:59 AM
tornLT1's Avatar
I would like to move as close to work as possible with gas price concerns, but I got to thinking about a story I read about some guy and his porsche.
His commute was 2 miles to work, and after 2 or 3 years of driving, he had burned completely through the piston rings. This was supposedly due to the constant short driving distances, which didn't allow the oil to warm up enough and flow everywhere it needed to.
What would be a safe, minimum consistent driving distance for a F-body, mainly talking about an LT1 here. Is this even a concern with these engines?
Old May 24, 2008 | 09:31 AM
Make sure you are using the recommended oil, with the correct low temperature flowability. GM recommends 5W-30, and that should protect the engine even with low mileage commutes. Watching my oil temperature gauge, the oil does not reach full operating temperature for at least 15 minutes of moderate driving. But the correct oil will provide the required oil flow at all temperatures.
On the other hand, an engine that runs excessively rich when cold can contaminate the oil, or wash the lubrication of the cylinder walls. And, short trips may not heat the oil enough to drive off condensate, leading to acid formation and damage to the bearing metals. Drive it hard at least once a week to insure the oil gets good and hot.
Old May 24, 2008 | 09:46 AM
MARKTHOMASBRAND's Avatar
My place of work is about 1.5 miles from my house,been doing that commute for the last 3 years with my Camaro LT1 with no problems .
Regards,Mark.
By the way I use 5w-30 semi synthetic oil.
Old May 24, 2008 | 11:15 AM
Regards,Mark.
Yep.... but you're driving on the wrong side of the road.....
Old May 24, 2008 | 11:19 AM
I'm usually overtaking euroboxes,so I mostly drive on the right .
Old May 24, 2008 | 12:59 PM
OBE1 95Z28's Avatar
Getting oil up to operating temperature burns off water vapor and other harmful bi-products of combustion to keep your oil from building up harmful acids. I agree with Injuneer, it takes about 15 minutes for my oil temp gauge to get up to 180F.
Old May 24, 2008 | 02:15 PM
tornLT1's Avatar
Any excuse to drive hard is a good excuse
Old May 24, 2008 | 02:21 PM
TeamingTealZ28's Avatar
HHAHAHAHAHHAA!!!!!!!!!
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
jayblev95
Dec 1, 2014 06:55 AM
