Metal found while changing oil
I have a 99 z28 LS1 camaro that just turned 75,000 miles. I have always changed the oil every 3000 miles using Mobil 1 synthetic. I have not had NOS a blower or beat on the car.
This last time while changing the oil I found copper looking metal in my oil pan.
I was thinking maybe the thrust bearing. I do not want to have to get rid of the car. Has anyone had this problem?
Re: Metal found while changing oil
Send the oil out for analysis. The report will tell you everything you ever wanted to know about the internal condition of your motor.
http://www.blackstone-labs.com/index.html
I dont know about the copper color, but I do know that in most cases you will find some metal shavings in your oil, Its normal...... However, if you find alot, such as a teaspoon or more, then you really should start to worry.... and that info that was given to you about going to blackstone labs is awesome, dont hesitate to do that.....
Jul 4, 2005 05:00 PM
HuJass
18
Jun 24, 2002 09:19 PM
