May have cross-threaded header bolt hole...
Old Jun 17, 2011 | 07:39 PM
19z28camaro02's Avatar
Exclamation May have cross-threaded header bolt hole...
Putting my headers in today, on the last bolt I noticed it was going in a little cocked with slight resistance. I removed the bolt, checked it, looked good. I even applied antiseize to the bolt, (split locks) before I put it in. Is there a way I can clean the hole without much difficulty?
Old Jun 18, 2011 | 09:20 PM
rv93's Avatar
Re: May have cross-threaded header bolt hole...
maybe re-tap it? that might do the trick. if you messed it up bad, drill it out a bit, tap it for a slightly bigger bolt. you can also drill out the hole in the header flange a bit. just an idea. good luck
Old Jun 19, 2011 | 09:13 AM
Start with a "thread chaser" (not a "tap") the same size as the current bolt. Might be able to salvage it without drilling and tapping.
Old Jun 20, 2011 | 02:38 PM
Since I was using split locks, I decided to use my dremel and cut 1/4 of the tip of one of the extra bolts out. Ran it in a few times.....worked like a charm.
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
