Madman Rack Guys Question for you.
Old Jan 17, 2006 | 02:05 PM
93ZM6Tally's Avatar
Did you guys weld the mounting tab to the front K-member. I got one the other day, I guess I was under the impression that this was a completely bolt on kit, but when it came, it came with a mounting tab that looks like it should be welded to the K. I called to be sure and thats what they're telling me.
Old Jan 24, 2006 | 11:50 AM
madman69's Avatar
Re: Madman Rack Guys Question for you.
Yes you need to weld the tab on to your k-member.
Old Jan 24, 2006 | 02:41 PM
93ZM6Tally's Avatar
Thanks man, I appreciate the help.
Mark.
Old Jan 26, 2006 | 03:51 AM
camaronutt's Avatar
Can you buy a K-member set up for that rack?? Just curious. Thanks
Old Jan 26, 2006 | 07:59 AM
93ZM6Tally's Avatar
I think I can answer that. This rack will fit stock mounting locations, so any K member with stock mounting locations would work fine. The rack comes with an additional metal "tab" that is bolted directly to the steering box that needs to be welded. I'm pretty sure that any K-member you buy would require this additional tab be welded.
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
96PolicePkg
Sep 13, 2002 01:08 PM
Red97LT1
Aug 7, 2002 05:45 PM
