Lt1 To A Ls1 -- Need Help
Old Dec 19, 2005 | 03:09 PM
detroit1994z28's Avatar
Not sure if I'm in the right thread or not. But I have a 94 camaro z28 with the lt1 engine. I wanted to put a ls1 engine in - Is there any modification needed?? Will it bolt directly up to everything -- What do I need to make this work - Mike
Old Dec 19, 2005 | 04:45 PM
Re: Lt1 To A Ls1 -- Need Help
Probably best to post this on "General F-Body Tech & Info"... so I'll move it there for you. A "search" might answer some of the questions, since its been discussed before.
Old Dec 19, 2005 | 06:59 PM
Capn Pete's Avatar
This same topic was recently discussed (although the guy who posted the question didn't realize at the beginning the extent of his question!).
http://web.camaross.com/forums/showthread.php?t=415747
...read TABAHR's post (post #15) ... he lists everything you'd need to do.
IMO, unless you've either got A) a lot of time and money on your hands, or B) too much currently invested in your car that you can't fathom putting money into another car, I would personally recommend selling your '94 and buying a '98+ LS1 car IF YOU WANT THE LS1, or just build your LT1. LT1's are great engines, and there's a ton of aftermarket for them. An LT1 -> LS1 swap hardly seems worth it in a '93 - '97 F-body.
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ddr698
Jan 9, 2015 10:05 AM
