Low horsepower draw AC compressor?
Old Mar 22, 2011 | 02:08 PM
AdsoYo's Avatar
I was watching a documentary on the C6.R Corvette and they mentioned how it uses an AC compressor that only takes 1.5 horsepower to turn instead of the 10-15 horsepower that a typical street car AC compressor uses. Does anyone know of an AC compressor that fits our LT1's that is super efficient like the C6.R compressor?
Old Mar 23, 2011 | 10:07 AM
Z28SORR's Avatar
Re: Low horsepower draw AC compressor?
Doesn't sound right! Why would a "race car" have an AC compressor?? Or are you talking about the GT2 street version?
Old Mar 23, 2011 | 09:16 PM
Its the GT2 class "race" rules. From Road & Track magazine:
Unfortunately, I couldn't ride in the race car. There's no passenger seat, and that side of the car is filled with air conditioning, drink bottle and electronics. Interestingly, the rules require air conditioning. The C6.R uses a compressor from a Cadillac SRX that's driven off the propshaft. The cold air is routed directly into a custom-made seat to more effectively cool the driver. Uniquely, the C6.R does not have a movable seat or pedals. To accommodate the swap between Magnussen and teammate Johnny O'Connell, there's a set of seat pads that go in. The steering wheel uses the factory column, and incorporates its tilt and telescope adjustments.
Old Mar 24, 2011 | 12:21 AM
AdsoYo's Avatar
Wow, I can't believe you dug that up, Injuneer. Too bad it's driven off a shaft instead of a belt.
Old Mar 24, 2011 | 05:16 AM
You can't do "magic" with the concept of compressing freon (or any other substance). The power required is directly related to the amount of heat (energy) transferred in the cooling process. It does not appear that they are running the A/C at a level required to cool an entire vehicle interior, just enough to cool the driver's seat a little bit. They have to have a compressor, but it doesn't mean you can cool an entire vehicle interior with 1.5HP. I suspect in it's Cadillac SRX application, its pulling way more power than that. Yes, it's more efficient than what we use, but it isn't going to give you a huge savings, if you use it the way it was intended.
I also don't think they are saying it is "shaft" driven in the sense that there is no pulley. I suspect is driven off a pulley on the C6.R driveshaft. Remember, the Corvette DS does not move up and down with the suspension. Its in a closed torque tube that rigidly connects the engine in the front to the tranny in the rear of the car.
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
Noct
Jul 14, 2015 01:18 AM
colts0455
Jul 7, 2015 07:19 PM
