Locked up A/C compressor
Old 09-18-2009, 03:31 PM
grumpygreaseape's Avatar
i have a locked up compressor in my camaro. i have disconnected it electrically. i am wondering if any of you have experienced the same problem? in addition to the compressor replacement and exp/orifice tube replacement, what was the extent of other parts required to do the job so the new compressor wont self-destruct again. did your evaporator, condenser, lineset need replacing as well? was the metal carnage within the system able to be cleaned out, and most old parts re-used? thanks.
grumpygreaseape is offline
Old 09-18-2009, 04:34 PM
rclearyiii's Avatar
I have used a garden hose and flushed out both the condensor and evaporator more than once in the past. After flushing, use a air compressor set about 5 psi and run air through both of them until they are good and dry. The same can be done with any hose sets. Of course..have the system put on vacuum prior to the recharge.
rclearyiii is offline
Aaront810
08-29-2020 09:34 PM
magman
04-15-2016 03:08 AM
colts0455
10-04-2015 09:47 PM
colts0455
09-27-2015 01:07 PM
z28cam1993
09-09-2015 04:08 AM
Quick Reply: Locked up A/C compressor
