Locked up A/C compressor
Old Sep 18, 2009 | 03:31 PM
grumpygreaseape's Avatar
i have a locked up compressor in my camaro. i have disconnected it electrically. i am wondering if any of you have experienced the same problem? in addition to the compressor replacement and exp/orifice tube replacement, what was the extent of other parts required to do the job so the new compressor wont self-destruct again. did your evaporator, condenser, lineset need replacing as well? was the metal carnage within the system able to be cleaned out, and most old parts re-used? thanks.
Old Sep 18, 2009 | 04:34 PM
rclearyiii's Avatar
I have used a garden hose and flushed out both the condensor and evaporator more than once in the past. After flushing, use a air compressor set about 5 psi and run air through both of them until they are good and dry. The same can be done with any hose sets. Of course..have the system put on vacuum prior to the recharge.
Aaront810
Aug 29, 2020 09:34 PM
magman
Apr 15, 2016 03:08 AM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
z28cam1993
Sep 9, 2015 04:08 AM
