window switch panel cracked
Are there any older chevys with similar clips?
I had where the metal clip slides into break off. So mine was looking like you pic so I ended up epoxing the whole thing. This all happen from repeated times of removing it and the door panel for window motor replacement then the speaker rattled from a loose bolt then the window rattled. Oh well if I have to removed it I will probable break lots of stuff.
may have a guy in ny that has that part, I bought some parts from him about three weeks ago and he had that still. I needed the bezel that went around the door handle. If you want I will look for the number and you can call him to see if he will ship it to you.
steve
steve
this recently happened to me during a window motor replacement. i grabbed a flashlight and a retrieval magnet and fished out the clip. pulled off the switch bezel from the car. mixed up a dab of jb weld and epoxied it together, 24 hours later i re-installed it. it was tight and good as new. seem like you need to dig out your old spring steel clip from inside the door.
Originally Posted by gmpartsdirect
GM PART # 9722397
CATEGORY: Keyless Entry Fobs & Batteries
PACK QTY: 25
CORE CHARGE: $0.00
GM LIST: $1.19
OUR PRICE: $0.71
DESCRIPTION: CLIP
PACK QTY: 25
CORE CHARGE: $0.00
GM LIST: $1.19
OUR PRICE: $0.71
DESCRIPTION: CLIP
Ordered the clips from Jason Cromer Friday. I think for (4) of them it was $3.xx
