Keyless Entry Question
Old Jan 27, 2024 | 09:13 PM
Woody25's Avatar
Good evening. Have a '95 Z28. I bought a new key fob from Ebay. I jumped #4 to #8 on the port and can get it to trigger programming mode, but can't get the key fob to work. Is there anything I need to check that could be keeping the new fob from communicating?
Thanks in advance!
Old Jan 27, 2024 | 09:38 PM
Re: Keyless Entry Question
Is the fob battery good?
Have you tried the Shoebox procedure?
4th Gen LT1 F-body Tech Articles
Or free (courtesy of GaryDoug) download of 1995 factory service manual?
https://www.mediafire.com/?40mfgeoe4ctti
Old Jan 27, 2024 | 09:50 PM
Woody25's Avatar
Yes sir. The batteries are good. I followed those exact instructions as well. I also have brand new door lock buttons that are fully operational. Now I'm wondering if I received a bad key fob, or if there's some something on the vehicle that may be disabled or faulty. Something not allowing the key fob to communicate.
Old Jan 27, 2024 | 10:02 PM
Did you take the jumper off the 4 - 8 pins?
Old Jan 27, 2024 | 10:08 PM
Woody25's Avatar
I did. Door locks cycle once when I jump them, but don't do anything when I press the button on the transmitter. They should cycle once the way I read it.
Old Jan 27, 2024 | 10:56 PM
Did you make any progress on your earlier thread?
https://www.camaroz28.com/forums/adv...s-dont-889939/
You never followed up on that.
Old Jan 28, 2024 | 11:56 AM
Woody25's Avatar
Just did. My apologies. As for this current issue, I dug through the owners manual and found three transmitter location. Next step for me will be to go verify everything common to the transmitter is in tact. I'll update once I know. Thanks!
Old Jan 28, 2024 | 12:11 PM
And just to be clear, appears fob will not work if the jumper is not removed from the pins.
Old Jan 28, 2024 | 12:33 PM
Woody25's Avatar
That's correct. It should cycle one time when you make the connection from 4 to 8, then cycle once again when you press a button on the fob. Then you should be able to remove the jumper and use the fob normally.
I can get the first cycle to happen, but nothing happens when I press the button when it's in program mode.
Old Jan 28, 2024 | 05:00 PM
If you open the fob case up, does it expose the actual tiny button on the circuit board that the cover membrane contacts? If so, open the cover and try pressing one of the buttons on the circuit board.
Just guessing on this, I never had a problem w/ my 94 Formula remote locking. Sold the car 2 years ago, so I can’t open the fob up and look at it. But I've always found the tiny buttons on other brand vehicle fobs I've opened up in the past.
shortman1124
Jul 9, 2006 02:54 AM
Red97LT1
Mar 26, 2006 01:36 PM
street demon2k3
Apr 10, 2004 02:34 AM
PipesTA
Aug 27, 2003 06:21 PM
PumpkinKingZ28
Mar 5, 2003 12:00 AM
