Just recharched A/C, now codes 67 and 69
Old Jul 1, 2011 | 07:53 PM
AdsoYo's Avatar
I just had the A/C recharged at a shop. The A/C system had been empty since May 2009 when I had my new engine put in. Before then it worked great. Now I have codes 67 (A/C refrigerant pressure sensor circuit (pressure sensor or A/C clutch circuit problem)) and 69 (A/C clutch circuit) and the compressor will not engage. These codes did not exist before I had my A/C recharged. The mechanics already left for the 3 day weekend so I'm on my own until Tuesday. Does anyone know what could be wrong?
Old Jul 1, 2011 | 09:28 PM
Re: Just recharched A/C, now codes 67 and 69
Try resetting the PCM and clearing the codes.
Old Jul 2, 2011 | 07:45 PM
sniperSS's Avatar
Yes, first thing clear codes.
Old Jul 3, 2011 | 01:36 PM
AdsoYo's Avatar
Cleared the codes. When I started the car they were gone. As soon as I turned on the A/C, code 67 came back and the compressor did not engage.
Old Jul 3, 2011 | 02:46 PM
That tells you right where you need to be looking.
Old Jul 3, 2011 | 04:30 PM
AdsoYo's Avatar
I also forgot to mention the fans turn on as they're supposed to when I try and turn on the A/C. So is it just a matter of making sure all the wires and connections are good? I did a quick glance and the pigtail is plugged in on the compressor. Any wires or connections in the interior I should check?
Old Jul 3, 2011 | 05:14 PM
Redneck2009's Avatar
yea im having this issue too only i have not run for error codes yet. my ac is blowing out hot air, replaced compressor, new one still wont engage but fan kicks on. so me and him might be having same problem
Old Jul 3, 2011 | 07:06 PM
AdsoYo's Avatar
I took a closer look at the pigtail on the compressor. There are two wires going to the compressor: a black one and a green one. The green one is cut flush with the pigtail. I'm guessing that's my issue? Not sure how that could've happened.
Old Apr 23, 2012 | 04:13 PM
AdsoYo's Avatar
For closure purposes: after ordering a new pig tail and soldering it on, the A/C works like a charm.
HectorM52
Jun 23, 2016 08:42 PM
timmy39120
May 8, 2015 11:41 AM
alphaauto
Feb 5, 2015 05:25 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
