Just recharched A/C, now codes 67 and 69
I just had the A/C recharged at a shop. The A/C system had been empty since May 2009 when I had my new engine put in. Before then it worked great. Now I have codes 67 (A/C refrigerant pressure sensor circuit (pressure sensor or A/C clutch circuit problem)) and 69 (A/C clutch circuit) and the compressor will not engage. These codes did not exist before I had my A/C recharged. The mechanics already left for the 3 day weekend so I'm on my own until Tuesday. Does anyone know what could be wrong?
Re: Just recharched A/C, now codes 67 and 69
I also forgot to mention the fans turn on as they're supposed to when I try and turn on the A/C. So is it just a matter of making sure all the wires and connections are good? I did a quick glance and the pigtail is plugged in on the compressor. Any wires or connections in the interior I should check?
yea im having this issue too only i have not run for error codes yet. my ac is blowing out hot air, replaced compressor, new one still wont engage but fan kicks on. so me and him might be having same problem
I took a closer look at the pigtail on the compressor. There are two wires going to the compressor: a black one and a green one. The green one is cut flush with the pigtail. I'm guessing that's my issue? Not sure how that could've happened.
