just a question.
Old Apr 1, 2008 | 05:53 PM
Bluovlh8er's Avatar
just a question.
can i run a 96-97 ss hood on my 95 z28 with out hooking up the ram air kit? i have a k&n cold air intake.
Old Apr 1, 2008 | 06:53 PM
joeSS97's Avatar
There is no reason why you couldnt.It will just let fresh air in under the hood.Or block it off if you are worried about water.
Old Apr 1, 2008 | 09:46 PM
OBE1 95Z28's Avatar
I've been running that way for the last 4 years with no issues. The car rarely is driven in the rain so I can't speak for possible rain issues.
Old Apr 2, 2008 | 02:24 PM
ss.slp.ls1's Avatar
Why would rain be an issue? The stock SS hoods have baffles in them for water.
Old Apr 2, 2008 | 02:29 PM
19z28camaro02's Avatar
you're just gunna be creating more of a drag issue vs. cooling the engine if you leave it open and not block it off.
Old Apr 2, 2008 | 07:56 PM
OBE1 95Z28's Avatar
He stated he wasn't using the ram air section; my assumption (always gets you in trouble) is that the baffles are in the ram air section.
Old Apr 2, 2008 | 11:42 PM
ss.slp.ls1's Avatar
He said he won't be running the ram air kit aka the air box and intake. The baffles are in the hood, well the real SS hood at least.
Old Apr 3, 2008 | 10:23 AM
Z28SORR's Avatar
That's correct. The hood has two baffles an upper and a lower, that help dirrect rain into under hood drain channels. They would still be there and work even without the air box & filter. This is for the OEM hoods only.
Latronaxe
Jul 20, 2015 12:00 PM
Relaquary
Jul 6, 2015 09:42 AM
sseeya
Apr 9, 2015 06:38 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
mongoose=
Mar 22, 2015 07:22 AM
